Previous Topic: New Job: SynchronizationNext Topic: Exclude Options
Options
You can apply the following options while comparing and synchronizing the directories:
Include Subdirectories
Includes the subdirectories of the source and target directories for comparison.
Delete Unknown files
Deletes those files in the target directory that are not available in the source directory.
Ignore File Attributes on Compare
Ignores the file attributes such as date created, modified, file permissions, and so on while comparing the directories.
Ignore File Attributes on Copy
Ignores the file attributes while copying the files from source to target. When a file in the target directory differs from the one in source directory—for example, if the file size is different—the synchronization job overwrites the file from the source to target.
Cancel overwrite if the difference in file size exceeds
Cancels the overwrite operation if the file size in the target directory exceeds a certain amount of KB. This prevents accidental copying of a large number of KB over the network.
