Previous Topic: Local Network FolderNext Topic: My Sessions Folder
Add Computer to Local Address Book
You can add computers to a local address book where you can more easily organize them.
  1. Select and right-click on a found computer. Use Ctrl to select several computers.
  2. Select Add to Local Address Book.
  3. Click Connections.
  4. Enter any extra values and click OK.
    The selected computer is added to the address book.
    Note: If multiple IP addresses are assigned to the same computer, the dialog is able to find it and multiple lines are used to store those addresses.
