After you have a computer configured in an address book, you can start a remote control connection.
Note: The computer you are attempting to locate may appear in the Local Address Book pane, Global Address Book pane (if Centralized security is enabled), or the My Favorites folder.
Alternatively, if you are already aware that the target computer is not switched on, and if Wake-on-LAN information is available for that computer, click Power Up on the Advanced tab of the Connection Settings dialog to send a Wake-on-LAN request.
Note: If the computer to which you are attempting to connect was available to connect, the viewer window displays the following message:
Unable to connect to remote machine, check that the remote machine is listening for connections.
