The SystemEngine pane shows the scheduled tasks due to run on the domain manager's main engine.
The Tasks pane has the following options:
Toggles the activation of the engine.
Forces the engine to start the next scheduled tasks immediately.
Opens the New Task Wizard where you can create a new task.
Opens the Select Engine Task dialog where you can choose a task to deploy to the engine.
Note: For detailed information about engine trace settings and the engine logs, such as TRC_SystemEngine_#.log, see the Implementation Guide.
