The Add Directory Argument dialog lets you browse the configured directories and query any of the objects in the directories.
Displays all the configured directories in a tree structure. Expand External Directories to view all the directories in the domain. Expand the individual directories to view the objects under them.
Displays the Uniform Resource Identifier (URI) for the selected object.
Displays the attributes that you can query for the selected object. Double-clicking any attribute opens the Set Attribute Filter dialog, where you can specify the filter value.
Important! If a directory query string contains any LDAP-reserved characters, such as !, &, ), (, and so on, then this query text is interpreted as an operator when queries are performed on external configured directories. Consequently, query processing fails because this operator is seen at an invalid point in the query filter.
