Previous Topic: User Account Properties: User Account TabNext Topic: User Account Properties: User Defined Tab
User Account Properties: Agent Tab
The Agent tab contains agent-related information.
This tab contains the following fields:
Agent Name
Identifies the agent name.
Registered
Identifies the date and time when the agent was registered.
Last Run
Identifies the date and time when the agent was last run.
Last IP Address
Identifies the last IP address of the agent. If the agent is configured through DHCP (Dynamic Host Configuration Protocol), each time the DHCP Server is restarted, a new IP address is assigned to all the systems connected to the server. This field displays the last IP address of the agent.
Server Host Name
Identifies the host name of the scalability server that this agent reports to.
Agent Restrictions
Shows the agent restrictions, if any. Valid restrictions are as follows:
Components and Version
Identifies the various agent plug-ins that support this user account.
Description
Provides a brief computer description.
