Previous Topic: New Software Category Dialog: Software Category TabNext Topic: Manufacturers Folder
Create New Product Dialog
Use this dialog to specify the general information about the definitions, such as the name and version.
This dialog contains the following fields:
Name
Defines a unique name for the definition
Version
Defines the version of the definition.
Example: V1.0.
Query Version
Defines the query version of the definition.
Example: 1.0.0.0
Manufacturer
Specifies the manufacturer of the definition. If the manufacturer you are looking for is not in the list, you can create a manufacturer in the Manufacturers folder.
Description
Describes the product.
