The History - Asset pane lets keep track of changes made to assets in the domain manager.
Shows the date and time when the event occurred.
Shows the type of event that occurred on the selected asset.
Shows the area affected by the event.
Shows the event name.
Shows the primary object involved in the event. For example, if you have linked a job to an asset, object 1 shows the asset name and object 2 shows the job name.
Shows the secondary object involved in the event.
Note: The name of the asset for which you are viewing history is shown in bold.
Shows the name of the user who triggered the current event. If the user name field shows ENGINE, an engine has triggered the event.
Shows the previous value if it has been changed since the last scan. For example, if the amount of memory has changed on a computer, the new and old values are shown.
Shows the new value if it has changed since the previous scan.
Right-click the History item in the tree view and select Clear History to delete history information for the current asset.
