The Inventory Item section lets you add the inventory item to be monitored.
This section contains the following field:
Lists all the inventory items in the domain including inventory template items. Select the inventory that you want to monitor.
Note: If you have enabled history tracking, you can see the history of changes in the History folder of the respective policy.
