Previous Topic: Policy HistoryNext Topic: System Engine
Enable History Tracking for Policies
History tracking keeps track of the changes made to the policies. You can enable history tracking for the event based policies only.
To enable history tracking
  1. Right-click the Policy and select Properties.
    The Policy Designer dialog appears.
  2. On the right side of the dialog, check the Enable History Tracking check box, specify the number of days of history you want to maintain and click OK.
    History tracking is enabled. You can view the history in the History folder of the policy.
