The File Collection section lets you add a configuration file to be monitored.
This section contains the following field:
Lists all the files available under the Control Panel, Configuration, File Collection folder. Whenever the selected file is modified, this event policy is triggered and the specified action is executed.
Note: If you have enabled history tracking, you can see the history of changes in the History folder of the respective policy.
