Previous Topic: Advanced Recognition Tab: System TabNext Topic: Get Package Release in Windows
Advanced Recognition Parameter Dialog: Package Tab
Use the Package tab to specify the information to be taken from the installed programs database in each operating system.
This tab contains the following fields:
Package Name
Defines the package name that should be checked in the installed programs database.
Version
Defines the package version. If this field is blank, the agent only validates the package name.
You can get this information from different sources depending on the operating system:
More information:
Get Package Version in Windows
