Previous Topic: Create New Release/Suite/Patch Dialog - Recognition TabNext Topic: Advanced Recognition Parameter Dialog: Package Tab
Advanced Recognition Tab: System Tab
Use the Systems tab to specify the operating system specific parameters for recognizing the definition.
A regular expression on this dialog refers to either the whole string or the string with special characters like *, %, and so on.
Note: The regular expression must match the entire string.
This tab contains the following fields:
OS Name
Specifies the operating system name. If you have selected Windows as the OS Group in the Recognition tab, this field is disabled because the OS name for all Windows operating systems is Windows. You can edit this field for UNIX/Linux.
OS Version
Defines the operating system version.
