You can initiate the synchronization of the Client Automation assets and inventory data with an existing MDB on Oracle or SQL Server by creating the Database Synchronization task. While creating the task, specify the credentials (connection properties) for the target database on the Specify connection details for the external database dialog of the Create New Task wizard.
To specify connection details for the Database Synchronization task
Lets you enter the session ID of the Oracle MDB. This ID is used to identify the database on the Oracle Server. The default value is orcl. This field is displayed when Oracle is selected as the target database.
Lets you enter the database instance on the SQL Server. This field is displayed when SQL Server is selected as the target database.
Lets you enter the port number for the Oracle MDB. This field is displayed when Oracle is selected as the target database. The default value is 1521.
Lets you enter the database name for the SQL Server MDB. This field is displayed when SQL Server is selected as the target database. The default value is mdb.
You can immediately test the settings you made by clicking the Test Connection button. The DSM manager then tries to open a connection to the target database. The result of this action is displayed next to the Test Connection button, for example, Connection failed.
