Previous Topic: Discovering Software Using IntellisigsNext Topic: View Intellisig Definitions
Verify the Execution of Content Download Job
The Default Software Contents Download job downloads the Intellisigs that are provided by CA from the CA website. Verify that this job has been executed at least once from the time you installed this release. The successful completion of the job helps ensure that the CA-provided Intellisigs are downloaded to your domain manager.
  1. Navigate to Control Panel, Engines, All Engines, System Engine.
    The engine log and Task List is displayed on the right pane.
  2. Verify that the Status of the Default Software Contents Download job displays OK and it was Last Executed after you installed this release.
    If either of these conditions is false, you can either run the job immediately or wait till the next scheduled time of the job. If both the conditions are satisfied, you can view the downloaded Intellisig definitions.
Back to Top
