The software discovery collect task lets you collect the software inventory from the agent computers. The asset management agent scans the computers and discovers the software based on either of the following methods:
Software signatures in asset management are created as software definitions. You can create software definitions for a product, release, patch, suite, or virtual application image. By default, asset management provides pre-defined software signatures covering the most widely used software in the IT industry.
Note: The new signatures pushed down by the scalability server for detecting virtual application images are specially tagged, such that they are ignored by legacy agents. Therefore, only Release 12.5 agents will process the signatures and inventory virtual applications correctly.
By default, the configuration given under the All Computers, Group Details, Configuration, Collect Tasks folder is applicable to all the computers. However, you can perform different types of scanning on different computers in the domain by creating new collect tasks.
