The All Scalability Servers folder includes all the scalability servers in the network that are registered with the domain manager.
The scalability server folder has the following context menu options:
Opens a new window allowing you to view all the scalability servers in this group.
Stages a sealed software package on all scalability servers. You can choose whether to stage the package with default or custom settings.
Removes all nodes in the tree view that have been added by double-clicking or pressing the Enter key on nodes in virtual lists. This option is available only when there are nodes in the tree.
Opens the Stage Software Package Wizard. For more information, see the Software Delivery Help.
Opens the Object Permissions dialog.
Opens the Group Properties dialog where you can view group-specific information about the current group of scalability servers.
