Previous Topic: Upgrade Computers WizardNext Topic: Control Panel
Policies
A policy is a tool used to automate repetitive or time-consuming maintenance and security tasks.
As a large amount of asset information is collected, it is likely that certain threshold values are exceeded or events occur. In such cases, policies help the administrator take action on critical data or on potential problems, such as low free disk space, installation of non-approved software applications, or hardware components being added or removed without authorization.
Policies can be assigned to users, computers, and groups.
The Policies folder provides these built-in policies:
All the policies that are violated by the asset are displayed in the Home Page of the respective asset.
Wake-On-LAN Policy Group
The Wake-On-LAN policy group lets you set policies for remotely and automatically powering up computers in your enterprise. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
WOL: Broadcast
Indicates the type of wake-on-LAN (WOL) datagram used to wake physical computers. Valid values are Unicast, Broadcast, and Broadcast + Unicast.
Default: Broadcast + Unicast
WOL: Enable guest nets
Indicates whether WOL datagrams can be sent to guest networks in addition to the original network where the computer is registered.
Default: False
Guest net address 1 - Guest net address 5
If Enable guest nets is set to True, specifies the network address of each guest net. Up to five guest nets can be specified.
Guest net mask 1 - Guest net mask 5
If Enable guest nets is set to True, specifies the subnet mask of each guest net. Up to five net masks can be specified.
WOL: Port
Specifies the UDP port to which WOL datagrams are to be sent.
More information:
Query Based
Event Based
