In the tree view of the Explorer GUI, the host name of the computer on which the MDB resides usually serves as the name of the first (root) node. The computer name is suffixed by the word Domain or Enterprise, which indicates whether the console is connected to a DSM domain manager or DSM enterprise manager.
Note: Client Automation supports the renaming of enterprise managers and domain managers through the DSM Explorer using the Enterprise Properties or Domain Properties dialog, respectively. The Name, Contact Information, and Description fields can be edited at the root level, and their values are replicated between enterprise and domain managers. However, Client Automation does not support the renaming of scalability servers.
The DSM Explorer tree view contains the following nodes:
The information pane on the right provides you with an overview of the system and is divided into the following portlets:
Displays information about the domain or enterprise in the System Status area of the Domain information pane. Clicking the Configure button in the upper-right corner of this portlet lets you navigate to the configuration mode.
Displays messages about license information for plug-ins.
Displays information about managed computers and users.
Displays the FIPS mode of the manager. Following are the possible values:
Displays the user account name for the currently logged in user.
Displays the total number and a list of policy violations, including list of systems which have inactive ITM or HIPS agents.
Displays the total number and a list of jobs that have failed.
Displays the number of discovered installations in excess of the number of approved licenses for specific software.
Note: The information about unlicensed software under System Status is available only if the asset management functionality is installed.
Displays the tasks currently scheduled or in progress.
Shows the DSM Explorer tree view nodes that you have used frequently. You can navigate to an item in this list at any time simply by clicking on it.
Launches basic features such as creation of a query, search facility, generation of reports, or deployment of software packages.
