The All Definitions folder contains all the software definitions known to this domain.
The All Definitions pane shows more detailed information about the individual software definitions such as name, type, description, manufacturer, and version information.
Double-click any definition item in the list to expand it in the tree view.
Right-click a software definition under All Categories to open its context menu:
Enables heuristic or signature scanning.
Disables heuristic or signature scanning.
Opens the selected software definition in a separate folder.
Copies the selected software definition to the clipboard and lets you paste it in a different folder.
Opens the Create new Release dialog.
Opens the Create new Suite dialog.
Opens the Organize Product dialog.
Deletes the selected software definition. Also deletes all discovered software records for this definition.
Opens the Object Permissions dialog.
Opens the Properties dialog for this software definition.
