You can create two types of user-defined groups—static or dynamic.
Identifies asset groups whose membership, unless modified manually, never changes. A static group contains only those assets that you have added.
Identifies asset groups that depend on a user-specified query to display members. The assets in a dynamic group fulfill the defined criteria (query) and are found dynamically by executing the query against the MDB.
