Previous Topic: Mark Time Interval in the GraphNext Topic: Detail View
Statistics View
The Statistics view provides detailed statistic information on the assets using the selected application in the specified time span.
This view has the following information:
Usage
Specifies the maximum, minimum, and average number of concurrent uses of the selected application.
Average
Shows the average number of times the selected application has been in use in the specified time span. For example, if the Average value is 2.5, the application has been used two to three times in the specified time span.
Note: The Average value can serve as an indicator for the numbers of licenses needed in your company.
Action Distribution
Counts the number of occurrences of the following events for the selected application:
Miscellaneous
Counts the number of times the application was started and the total number of different users running the application.
