Depending on the settings given in the Auditing tab, all activities concerning the .dll and/or .exe files to be monitored are displayed. Only the applications that have been started and stopped on the computer asset are displayed in this window; starting an application and running the asset management agent will not create any entry.
Note: You must select at least one application to be monitored for software usage in the Application tab to enable the auditing option. Enabling the auditing option degrades the agent performance considerably.
