Previous Topic: New Domain Wizard - FinishNext Topic: Search Results Pane
Remove a Domain from an Enterprise Manager
The enterprise manager can have many domains linked to it. In a large network, a domain may need to be removed if the enterprise manager becomes unavailable or is uninstalled. Sometimes a domain may need to be unlinked from an enterprise manager for operational reasons.
To remove a domain if the enterprise manager has become unavailable or has been uninstalled
  1. Open a domain in a Domain Explorer window.
  2. Right-click the domain name root node and select Remove from Enterprise from the context-menu.
    A message is displayed confirming that the enterprise manager may not be available on the network or there is no link to your domain manager.
  3. Click OK.
    The domain is removed from the enterprise manager.
To remove a domain from an enterprise manager
  1. Expand the Enterprise node and right-click Control Panel, Domains, All Domains, domain name and select Remove from Enterprise from the context menu.
    A message to confirm the removal of the domain manager from the enterprise manager is displayed.
  2. Click Yes.
