Asset Management › Software › File Explorer › Search for a File in the File Explorer › Search Files Based on the File Size
If you want to search for a file based on the file size, you can specify the search criteria in the Advanced tab.
To search files based on the file size
- Select At least or At most from the Size is drop-down list. This allows you to specify the minimum (At least) or maximum (At most) size for the file.
- Enter the amount of KB for the file size. For example, to search for files that are more than 1 MB, select At least in the Size is drop-down list and enter 1024 in the KB field.
