Asset Management › Software › File Explorer › Search for a File in the File Explorer › Search Files Based on the Modified Date
If you want to search the files created or modified during a specific time, you can specify the search criteria in the Date Modified tab in the File Search dialog.
To search files based on the modified date
- Select the All Files option if you want to search all the files for the given search criteria, regardless of date and size. This is the default option.
- Select the Find all files created or modified option if you want to search the files created or modified during the specified date range. You can select from the following options:
- between ... and
Searches only those files that are created or modified during the specified date range. Enter a start date and end date.
- during the previous ... month
Searches only those files that are created or modified in the specified months, for example, previous 3 months.
- during the previous ... days
Searches only those files that are created or modified in the specified days, for example, previous 10 days.
More information:
Search Files Based on the File Size
