Asset Management › Collect Tasks › Template Inventory Collect Task › Select Modules for Template Inventory Collect Task
You can use the Template Modules tab to view and select the user-defined template modules.
To select modules for template inventory collect task
- Select the templates you want to publish to the agent from the Template Modules list. This list includes all the template modules created under the Domain, Control Panel, Configuration, Collection Modules, Inventory Template Modules folder.
- After selecting the template module, click Preview.
The MIF Explorer window appears and displays the template structure and the information collected by the template. This is the structure you will see in the Inventory, Additional folder if this inventory is collected. Click the items in this explorer to view the complete structure of the selected template.
- Click Close.
The Schedule new Collect Task dialog appears.
Click OK.
More information:
View or Modify Existing Inventory Templates
Collect Tasks
