To back up a file on an asset, you must first configure it for backup at the asset or group level. Once configured, the asset management agent backs up this file whenever it is modified.
To configure a file for backup
The files configured for backup in the asset or group are listed.
The Select files to collect dialog appears listing the existing file definitions that you can back up.
The selected files are marked for backup and appear in the right pane.
