The Select files to collect dialog displays the configuration files you can back up. You can view, select, and clear the files to be backed up.
This dialog contains the following fields:
Displays the files that are configured for backup. From the list, select the files you want to back up, or clear the files you no longer want to back up. If the file that you are looking for is not in the list, add the file definition to the domain.
Displays the domain in which the configuration file is available.
