Previous Topic: Preregistration Wizard - Network Identification PageNext Topic: New Computer Preregistration Wizard - Scalability Server and Agent Selection Page
Preregistration Wizard - Operating System Image Page
The Operating System Image page appears if you have checked the Use OS Installation Management to setup a new operating system check box in the previous page of the wizard. This page defines which operating system is installed on the registered computer.
Select an OS Image to specify the new operating system
Defines the image that is used to deploy a new operating system on the registered computer.
Operating System
Defines the exact name of the operating system that is deployed.
Note: Available categories and options may vary depending on the products and components installed.
