Previous Topic: System StatusNext Topic: Configure Virtual Host Inventory Collect Task
Virtualization
The Virtualization node and corresponding pane display information about discovered virtual machine guests and virtual machines, which are listed in the Virtual Machine Guests and Virtual Machines subfolders, respectively. Note that the term virtual machines is a generic term, not used just for VMware virtual machines.
Note: The availability of this node depends on whether the asset is a virtual host or not. Additionally, the inventory information available in this pane depends on the host type: HP, IBM, Sun, or VMware.
For example, this pane contains the following columns for Sun virtual hosts:
Information
Displays several portlets with additional information like useful links, tips to work with the objects selected, and other tasks that can be accomplished in this pane. You can use the Customize Information Pane dialog to customize the layout of the portlets on this pane.
Host Name
Identifies the host name of the virtual machine.
IP Address
Displays the IP address of the virtual machine.
State
Displays the state of the virtual machine, for example, Active or Powered Off.
Operating System
Shows the operating system of the virtual machine.
MAC Address
Identifies the MAC address of the virtual machine.
Host Identification
Displays the virtual host name or ID.
Server
Displays the name of the server hosting the virtual machine.
More information:
Add Inventory Information to Overview
Change Attribute Value
Show or Hide Inventory Columns
View all Virtual Machines Connected to a Virtualization Server
Limit the Virtual Hosts to be Inventoried
