Previous Topic: Configure Additional Modules for a New Collect TaskNext Topic: Add Inventory Information to Overview
Change Attribute Value
You can change the value assigned to an attribute of an inventory item and update the database with the new value.
To change the value of an attribute
  1. Double-click the appropriate inventory attribute.
    The Change Attribute Value dialog appears.
  2. Modify the value for the following options, as required:
    Attribute
    Lists all the attributes for the selected inventory item. Select the attribute for which you want to change the value.
    Value
    Lists the values you can assign for the attribute. Enter the value you want to assign.
    Lock value and ignore changes reported by the agent
    Locks the value for the selected attribute. This means that any value reported by the agent will be ignored. Select this option, if you do not want the agent to overwrite the current value.
    Collected At
    Displays the date and time when the value was last collected by the agent.
    Old Value
    Displays the previous value assigned to the attribute.
    Do you wish to create a script job
    Creates a script job to change the value in the computer asset. Select this check box only for the template inventories.
  3. Click OK.
Note: After closing this dialog, press F5 to see the changes.
More information:
Inventory
