Previous Topic: Show Computer Configuration InformationNext Topic: Schedule a Policy
Apply Configuration Policy to an Asset
After you create and seal a policy, apply it to an asset (a computer or group).
Follow these steps: (To an Asset)
  1. Navigate to the Configuration Policy folder under the Control Panel node in the tree view.
  2. Right-click the policy to apply, and select Copy from the context menu.
  3. In the tree view, navigate to the asset, right-click it, and select Paste from the context menu.
    The policy is applied to the asset.
Follow these steps: (To Multiple Assets or Groups)
  1. Select the assets or groups in the tree view.
  2. Right-click the highlighted targets and select Paste from the context menu.
    Another context menu appears.
  3. Click Configuration Policies.
    The Schedule Policies dialog opens.
  4. Schedule the policy to be activated.
    Note: When you apply policies to a single asset or group, the feature enables the Customize and Preview button. The feature disables the button if you paste a policy to multiple assets or groups.
  5. Click OK to apply the policy to the multiple assets or groups.
