The File System pane displays the file systems and partitions on the computer asset.
Note: The inventory information available in this pane depends on whether asset management is installed.
This pane contains the following columns:
Displays information about all local drives on the computer such as size, free space, type, or file system.
Displays information about all the logical volumes on the computer such as volume size, volume free, or drive model.
Displays information about all of the partitions available, such as partition type, file system, size, or drive and volume devices.
You can also see whether the partition is recognized. The Recognized Partition column displays True if the file system for the partition is a known type of Windows NT. Otherwise, it displays False. For example, Linux partitions are displayed as False.
Displays information on all the mapped network drives or printers connected to the computer such as size, free space, type, or file system. This inventory information is collected by the General Inventory module which is by default linked to the All Computers group and runs at the scheduled time.
The following columns display the value for each of the preceding attributes:
Displays the scanned inventory item such as total memory and speed.
Shows the value of the items.
Shows the last modified value.
Shows the date when the item was last modified.
Note: You can show or hide these columns.
