Previous Topic: Input DevicesNext Topic: Storage
Power Settings
The Power Settings pane displays the information about the power settings, such as support hibernation, and Uninterruptible Power Supply (UPS) presence, policies set for the power settings, and power management attributes for Green IT Assessment.
This pane includes the following node:
Power Policy
Includes the following power management attributes of the assets for Green IT Assessment. If the system has a battery present, the DC settings are shown. There is a DC setting for each AC setting, for example, DC – Monitor Timeout. If the attributes are not retrieved, the status is displayed as Unknown in the user interface.
The Power Policy node also includes the AC Policy group that contains the following parameters:
And, groups within the AC Policy group contain the following items:
The parameter timeout value of 00:00:00 signifies Never, which means that the timeout will never occur. However, any other time is the actual timeout value in the form of hh:mm:ss (hours:minutes:seconds), for example, 00:10:00 signifies 10 minutes timeout.
Note: This inventory information is collected by the General Inventory module and is available only if you have installed asset management.
The following columns display the value for each of the preceding attributes:
Attribute
Displays the scanned inventory item such as total memory and speed.
Value
Shows the value of the items.
Previous Value
Shows the last modified value.
Date
Shows the date when the item was last modified.
Note: You can show or hide these columns.
More information:
Add Inventory Information to Overview
Change Attribute Value
Show or Hide Inventory Columns
