Previous Topic: Modify Contents of Files in the CMP FileNext Topic: Undo All Actions on Files in the CMP File
Undo Actions on Files in the CMP File
You can undo the previous and not-yet-saved actions on files in the CMP File. The Undo function applies to files that have been marked for adding, deleting, or modifying.
To undo the previous and not-yet-saved actions on files in the CMP File
  1. Select one or more file entries from the CMP File.
  2. Do one of the following:
    After the modifications on the selected files are undone, all file status symbols in the left margin of the CMP File window are reset to the File in hibernation symbol File in hibernation icon .
