Displays a message describing all the dmsweep subcommands and their syntax. This message is also output when the dmsweep command is executed without arguments.
Subcommand format:
help usage
Example:
The following example shows how you can use the dmsweep help command-line utility to display subcommands, options, and arguments.
dmsweep dmsweep help dmsweep usage
