The methods of this section are valid for enterprise manager only.
Note: The terminology of CA Client Automation has changed in comparison with Unicenter Software Delivery 4.0. The SD "area" is equivalent to the Client Automation "domain", while the SD "domain" is equivalent to a Client Automation group of domains.
Nevertheless for compatibility reasons the terminology, command, and parameter names of the CLI have not changed!
To avoid any ambiguity, in the subsequent sections an area (a domain in the terminology of CA Client Automation) is mentioned as a "Client Automation domain", and a domain (a domain group in the terminology of CA Client Automation) is mentioned as "Client Automation domain group".
The Client Automation domains are handled by the area command of the CLI and the Client Automation domain groups by the domain command of the CLI.
This section contains the following topics:
add—Add Domains to Domain Groups
addSubDomains—Add Domain Groups to Domain Groups
listMembership—List Domain Supergroups
modify—Modify Domain Group Attributes
remove—Remove Domains from Domain Groups
removeSubdomains—Remove Domain Groups from Domain Groups
