The renew command is valid only when issued from the enterprise manager.
Renew is used to renew a failed or halted distribution.
renew name=distribution_name
[sendTime="YYYY-MM-DD hh:mm"] [haltTime="YYYY-MM-DD hh:mm"]
Specifies the date and time at which a distribution order should be halted. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm".
Specifies the name of the distribution to be renewed.
Specifies the time to send the associated distribution to the addressed domain managers. The date has to be specified in the ISO format "YYYY-MM-DD hh:mm". If the parameter is not coded, the actual date and time is used.
