This action lists for a target computer the install parameter related to the associated OS installation order.
It lists the installation parameters related to the OS installation order specified. If "planned" is coded the parameters of the planned OS installation order are listed, if "scheduled" is coded the parameters of the OS installation order that is being launched for installation are listed, and if none of them or "current" is coded they are listed from the current OS installation order.
If the target computer is not a OSIM managed system, the action fails.
targetComputer action=ShowInstallParameter
name=computer_name
[planningLevel={current|scheduled|planned}]
Specifies the name of the computer of which the install parameters are listed.
Optional Parameter. Determines the configuration from where the parameters are taken.
The install parameters of the current OS installation order are listed. (Default)
The install parameters of the OS installation order scheduled for execution are listed.
The install parameters of the planned OS installation order are listed.
