This action provides information about the jobs assigned to the specified software policy.
The syntax of the action is as follows:
swPolicy action=listItem
name=software_policy_name
[swpScope={distributed | local}]
[detailed]
The name of the software policy its jobs will be listed.
This option determines the type of software policy involved in the action.
If there is a locally created software policy of the required name then this one is taken, if not it is looked for a policy distributed from an enterprise manager. The latter is on domain managers only.
The specified software policy has to be a policy created at the enterprise manager and distributed to the addressed manager.
(For domain managers only)
The specified software policy has to be a locally created policy.
Note: On enterprise manager all software policies have to be of type local.
If coded a detailed list is provided otherwise only the names of the assigned jobs are listed.
The short list provided is of the following format:
List Jobs Assigned To Software Policy «software policy name»
Short
«name of job 1»
«name of job n»
The detailed list is of the following format.
Detailed
Job name : «name of job 1»
..Item name : «name of item»
..Item version : «version of item»
..Procedure name : «procedure name»
..Job task : {configure|activate|
install|uninstall}
..Position : «position of the job»
..Reinstall required : {yes|no}
..Preaction : {none|reboot|logoff}
..Postaction : {none|reboot|logoff|
rebootAtEnd|logoffAtEnd}
..Prompt user : {yes|no}
....Allow cancel : {yes|no}
....Execute jobs if prompt times out : {yes|no}
....Prompt during (days/hours) : d/h
..Run offline from server : {yes|no}
..Run at shutdown : {yes|no}
..Prevent user login : {yes|no}
..Job startup : {local|global} time/{exact|at boot}
..Delivery calendar : «delivery calendar name»
..Ignore job calendars at target : {yes|no}
..Resolve query groups : {yes|no}
..Stage item : {yes|no}
..User parameters : «user parameters»
..Job time out (days/hours) : d/h
Job name : «name of job 2»
Job name : «name of job n»
