The procedures file consists of entries of the following syntax:
item = item
version = version
procedure = procedure
task={install|configure|activate|uninstall}
[deliverytime="YYYY-MM-DD hh:mm" ]
[attime="YYYY-MM-DD hh:mm" ]
[after={exacttime|boottime}]
[calendarname=deliverycalendar]
[preaction={none|reboot|logoff}]
[postaction={none|reboot|logoff|rebootAtEnd|logoffAtEnd}]
[promptUser={y|n}]
[allowCancel={y|n}]
[execTimedOut={y|n}]
[prompt=days.hours]
[offline={y|n}]
[RunAtShutdown={y|n}]
[PreventLogon={y|n}]
[GlobalTime={y|n}]
[nocalendar={y|n}]
[ResolveQuery={y|n}]
[Parameters=userparameter]
[stagingserver={y|n}]
[JobTimeout=d.h]
Name of the group item this entry is related to
Version for the group item this entry is related to
Specifies the item procedure to be performed
Specifies the procedure type.
The following types are valid:
The procedure installs the item.
The procedure configures the item
The procedure activates the item.
The procedure uninstalls the item.
If the parameter is not coded, install is assumed.
The parameters "item", "version", "procedure", and "task" have to be coded at each line as the first parameters and they have to be coded in the order as in the syntax definition previously shown. The remaining parameter can be coded in any order.
The meaning of the other parameters corresponds to the meaning of the command parameters shown in cadsmcmd jobcontainer action=addjob.
The procedure options for a job procedure are taken from the settings in this list.
If for a procedure an option is not coded in the related list entry then it is taken from the settings on command layer.
If it is not coded there then it is taken from the procedure options registered.
