Consider the unsealed job container "myContainer". Assume that the item "prod 1" of version 1.0 should be installed at KKKK01A and KKKK01B using the install procedure "inst". The user at the targets should be prompted for installation. The install order should be placed into the job container "myContainer".
The following command will provide the required job:
cadsmcmd jobContainer action=addJob name=myContainer item="prod 1" version=1.0 procedure=inst task=install computer=KKKK01A computer=KKKK01B promptUser after=exacttime
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ... ok. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CCNF USD OSIM Generate job "prod 1 1.0:inst": OK. SDCMD<A000000>: OK
