Basic information should be listed for the policy “enableUserProfiles”. This can be achieved by invoking:
cadsmcmd comConf action=showPolicy name=enableUserProfiles pType=computer
The information returned looks as follows:
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ...OK. Manager: myDomMgr.ca.com Domain: myDomMgr Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- Show Policies ------------------------------------------------------------------------------- Policy Name............................: enableUserProfiles ..Type.................................: COMPUTER ..Comment..............................: ..Status...............................: sealed Number of policies listed: 1 SDCMD<A000000>: OK
Note: The name of a section is the absolute section path starting at policy's root of the format
"/section_1/section_2/section_3".
The section name can also be seen at the Unicenter Client Automation Explorer's Internal Name column.
When detailed information is needed then the following command should be invoked:
cadsmcmd comConf action=showPolicy name=enableUserProfiles pType=computer detailed
The information presented might look as follows:
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ...OK. Manager: myDomMgr.ca.com Domain: myDomMgr Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- Show Policies ------------------------------------------------------------------------------- Policy Name............................: enableUserProfiles ..Type.................................: COMPUTER ..Comment..............................: ..Status...............................: sealed ..Parameter Sections ....Parameter Section Name.............: /itrm/agent/solutions/usd_agent ......Identifier.......................: 8AC0F5E8-292F-11DB-979E-96A4044440CB ......Parameters ........Parameter Name.................: SupportedUnitTypes ..........Identifier...................: 8ACCE1AA-292F-11DB-979E-96A4044440CB ..........Value........................: Computer ComputerUser Number of policies listed: 1 SDCMD<A000000>: OK
When in addition the parameter description is needed then the following command should be invoked:
cadsmcmd comConf action=showPolicy name=enableUserProfiles pType=computer detailed desc
This would result in the following information
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ...OK. Manager: myDomMgr.ca.com Domain: myDomMgr Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- Show Policies [DETAILED[desc]] ------------------------------------------------------------------------------- Policy Name............................: enableUserProfiles ..Type.................................: COMPUTER ..Comment..............................: ..Status...............................: sealed ..Parameter Sections ....Parameter Section Name.............: /itrm/agent/solutions/usd_agent ......Identifier.......................: 8AC0F5E8-292F-11DB-979E-96A4044440CB ......Parameters ........Parameter Name.................: SupportedUnitTypes ..........Identifier...................: 8ACCE1AA-292F-11DB-979E-96A4044440CB ..........Value........................: Computer ComputerUser ..........Parameter Info Name..........: pi_SupportedUnitTypes ..........Attributes ............Attribute Name.............: ppath ..............Value....................: /itrm/agent/solutions/usd_agent/suppor .........................................+ tedunittypes ............Attribute Name.............: desc_ja ..............Value....................: ............Attribute Name.............: string2_ja ..............Value....................: ............Attribute Name.............: string1_ja ..............Value....................: ............Attribute Name.............: desc_fr ..............Value....................: Les types d'unités pris en charge par .........................................+ le module d'extension de l'agent. ............Attribute Name.............: string2_fr ..............Value....................: Ordinateur + profil utilisateur ............Attribute Name.............: string1_fr ..............Value....................: Ordinateur ............Attribute Name.............: desc_de ..............Value....................: Die vom Agent-Plugin unterstützten Ein .........................................+ heitstypen. ............Attribute Name.............: string2_de ..............Value....................: Computer + Benutzerprofil ............Attribute Name.............: string1_de ..............Value....................: Computer ............Attribute Name.............: desc_en ..............Value....................: The types of units supported by the ag .........................................+ ent plugin. ............Attribute Name.............: string2_en ..............Value....................: Computer + User Profile ............Attribute Name.............: string2 ..............Value....................: Computer ComputerUser ............Attribute Name.............: string1_en ..............Value....................: Computer ............Attribute Name.............: string1 ..............Value....................: Computer ............Attribute Name.............: type ..............Value....................: stringlist Number of policies listed: 1 SDCMD<A000000>: OK
When beside the basic information additional information about the configurations the policy is being attached to is needed too then the following command should be invoked:
cadsmcmd comConf action=showPolicy name=enableUserProfiles pType=computer memof
The information returned might look as follows:
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ...OK. Manager: myDomMgr.ca.com Domain: myDomMgr Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- Show Policies ------------------------------------------------------------------------------- Policy Name............................: enableUserProfiles ..Type.................................: COMPUTER ..Comment..............................: ..Status...............................: sealed ..Member of............................: $AllComputer_update:1155623899 ....Target.............................: $AllComputer Number of policies listed: 1 SDCMD<A000000>: OK
