dsmPush check
Checks whether deployment packages exist at the local system and lists the packages found. The tool dsmPush does not check for Software Delivery packages. The list of packages found by dsmPush contains the following information:
The information is written to the check-output-file. Its name defaults to DSM_dsmPush_check_output.txt.
On Windows, its location defaults to the temporary folder (%TEMP%)
On Linux, its location defaults to $CA_ITRM_BASEDIR/logs if that variable is set or /tmp if not.
