This action deregisters a software template or policy at the domain manager from the enterprise manager.
This action is valid on enterprise managers only.
templateGroup action=deregister
name=template_group_name
[swTemplate=software_template_name]
cname=[name]
{{area=area_name} | {domain=domain_name} | toAllAreas}
[sendTime="YYYY-MM-DD hh:mm"]
[haltTime="YYYY-MM-DD hh:mm"]
[distPriority={1,...,10}]
Specifies the name of a domain manager from where the template is deregistered. The parameter can be coded more than once to address a list of domain managers.
This parameter should not be coded with the domain or the toAllAreas parameter.
Specifies the optional unique name of a distribution container used to ship the deregistration request.
If a job container / distribution with the specified name already exists an error will be reported.
If "cname" is not coded, a generic name is generated.
Specifies the priority that will be assigned to the distribution.
The priority specified has to be numeric and its value has to be greater or equal 1 and less or equal 10.
If not coded priority 5 is assumed.
Specifies the name of a domain manager group from its members the template is deregistered. The parameter can be coded more than once to address a list of domain manager groups.
This parameter should not be coded with the area or the toAllAreas parameter.
Specifies the date and time when the deregistration will be stopped, if it is not processed yet. The date is given in ISO format and should be at least 1 hour after the start time. If not ocded a halttime is generated as starttime + 1 hour.
Specifies the template group name.
Specifies the start time of the distribution from the enterprise. The date is given in ISO format. If not coded the actual date/time is taken.
Specifies the name of the software template to be deregisterd.
If not coded the default name is taken, i.e. “<group name> [$date $time]”.
All domain managers currently registered at the enterprise manager will be addressed for deregistering the specified software template or policy.
