This action deletes an existing software template or the whole template group. The group must be unsealed!
templategroup action=delete
name=template_group_name [swTemplate=software_template_name]
Specifies the template group name.
Whether the group is deleted or only a specified software template depends on the parameter swTemplate.
Specifies the name of the software template.
If specified, only the specified software template is deleted, the group itself and possible additional software templates associated with the group remain.
If not specified then the group and all its associated software templates are deleted.
