This action lists detailed information about existing jobs that are associated with the members of this group.
This action is valid for domain managers only.
compgroup action=listJobs
name=group_name
[groupScope={global | local}]
Name of an existing computer group. Information about existing failed jobs associated with the group members is listed.
The name might contain database wildcards, for example,
“%” for an arbitrary even empty sequence of characters
”_” for an arbitrary single character.
Specifies the scope of the group specified. The following values are valid for this option:
The group is a global group, created at an enterprise manager. It may be replicated to a domain manager.
Specifies a local group, created at the domain manager the CADSMCMD is connected to.
If groupScope is not coded then the groups are not checked for being a local or global group.
The information retrieved is presented as follows:
----------------------------------------------------------------------------- List of jobs associated with group group_name
----------------------------------------------------------------------------- Computer group name......: group_name ..Target.................: target computer name ....Job name.............: job name ....Job identifier.......: computer job identifier ....Item name............: item name ....Item version.........: item version ....Procedure name.......: procedure name ....Task.................: task ....User parameters......: user parameters ....Job state............: job status ....Error code...........: error code ....Error message........: error message ....Creation date........: yyyy-mm-dd ....Creation time........: hh:mm ....Activation date......: yyyy-mm-dd ....Activation time......: hh:mm ....Completion date......: yyyy-mm-dd ....Completion time......: hh:mm
