This action lists detailed information about failed jobs that are associated with the members of this group.
This action is valid for domain managers only.
compgroup action=listFailedJobs
name=computer_group_name
[groupScope={global | local}]
Specifies the name of an existing computer group. Information about existing failed jobs associated with the group members is listed.
The name might contain database wildcards, for example,
“%” for an arbitrary even empty sequence of characters
”_” for an arbitrary single character.
Specifies the scope of the group specified. The following values are valid for this option:
The group is a global group, created at an enterprise manager. It may be replicated to a domain manager.
Specifies a local group, created at the domain manager the CADSMCMD is connected to.
If groupScope is not coded then the groups are not checked for being a local or global group.
The information returned is formatted in the same way as for the action listJobs of compgroup.
