All parameter names of the commands are case-insensitive, the values assigned to them may not be. For example, a path name on Windows may be case-insensitive, on Linux it is definitely not. Parameters can be preceded by a hyphen (-) but this is optional. To avoid any ambiguity, use the preceding hyphen when coding a batch file.
The CLI uses the blank as a delimiter to separate parameters, options, and commands. If a parameter value contains a blank, then the parameter value should be enclosed in quotes. As the quotes should not be interpreted by a shell or command prompt but by the CLI, it might be necessary to escape the quotes from a shell or command prompt by preceding backslashes (\).
Note: The CLI reports errors only on parameters not known to the CLI or to inconsistent parameters. If a parameter is coded with a command or action that is not mentioned in the syntax description (but it is a defined parameter of the CLI and used by other commands), then the parameter is ignored for the coded command or action. No error or warning is displayed.
